Order Ford 8N Parts Online
8N drawbar pin
Rtex
08-10-2000 15:10:54
I have a 50 8N. There is a large verticle pin
below the PTO. I think it is the drawbar pivot
point. How to you remove the pin? I want to
hook a chain around it. It has a head, of sorts, on the bottom but I haven't been able to turn it.
Does the pin screw into the bottom of the tractor?
If so, are the threads normal right handed threads?
Michael Az
08-10-2000 16:04:03
 Re: 8N drawbar pin in reply to Rtex, 08-10-2000 15:10:54
No threads in there Rtex. There is supposed to be a spring inside that housing. You push up from the bottom on the pin and rotate it to remove. If your pin isn't moving, its probaly rusted or packed with dirt.
