Junction block?
rob 8N KS
08-13-2000 15:37:29
What is the purpose of the junction block in the wiring diagram? It is just a common terminal?
Mine is clearly shot (missing pieces) and the last owner's 12V conversion bypassed this block. I discovered this while installing the TISCO 12V kit.
While I get a replacement, can I just wire everything together that is supposed to be wired to the junction block?
Dell (WA)
08-13-2000 16:18:02
 Re: junction block? in reply to rob 8N KS, 08-13-2000 15:37:29
Rob..... ...junction block, terminal block....justa handy way to make electrical connections without them shorting out and arc welding on the dashboard. Its just a little neater than hanging wires dangling out in space and wrapping 'em with insulative tape. Do it right when ya' gots the chance, be proud of your work. Also prevents problems in the future. ..... ...Dell
rob 8N KS
08-14-2000 09:50:04
 Re: Re: junction block? in reply to Dell (WA), 08-13-2000 16:18:02
Is this part the same thing as what my ford parts manual refers to a a "Resistor Assy?" (#12250)
I can't seem to find any sort of junction block in the parts manual.
Gaspump
08-14-2000 12:48:52
 Re: Re: Re: junction block? in reply to rob 8N KS, 08-14-2000 09:50:04
The junction block used on the side distributor 8N is part#8NNN 14448. Got two new from the CNH last spring, they had to order them.
rob 8N KS
08-14-2000 12:57:01
 Re: Re: Re: Re: junction block? in reply to Gaspump, 08-14-2000 12:48:52
Ok, that's wierd, 'cuz my 12V TISCO kit has separate instructions for the front distributor 8N, and it refers to a junction block.
Sure enough, the ford catalog shows that part for the side mount only.
Hmm. Have to look again.
