Loose coil?
rob 8N KS
08-14-2000 07:57:51
I just replaced the coil on my 8N front dist.
Is this thing supposed to be a little loose? Or it is supposed to be completely flush with the distributor?
I can rock it back and forth about 1/4" even after it's clipped down.
Bob (KY)
08-14-2000 17:36:35
 Re: loose coil? in reply to rob 8N KS, 08-14-2000 07:57:51
Try adjusting the hold down by bending it a little AND make sure you have a gasket.
I believe the parts we're getting anymore are not true to form as they should be. My new coil didn't fit snug either not to mention some other parts that didn't fit just rite. Had a set of points that wouldn't adjust to less than .025. Talk about a head scratcher.
Good Luck
Bob (KY)
JerryU
08-14-2000 08:17:20
It is supposed to be tight with a cork gasket in between. I bought a 12 volt coil from somewhere (shudder the thought-12 volts (-:) and had to grind one of the internal ribs down a little to get it to sit tight.
I also coated the gasket with silicone dielectric grease and sprayed the whole thing with ignition sealer when I got it together.
Could hose down engine and it never gave me a problem.
JerryU
rob 8N KS
08-14-2000 08:21:22
 Re: Re: loose coil? in reply to JerryU, 08-14-2000 08:17:20
This one's a 12 v too. I'll take another look at it.
