Order Ford 9N Parts Online
PTO Over Run Clutch for 9N
Pete H
08-14-2000 20:38:08
Does anyone make a ORC for a 9N which fits without modification? The one I found would have to have the treads that the PTO cap screws into cut out in order to install. I want to be able use the cap when not using the PTO. Thanks
John
08-14-2000 21:13:55
 Re: PTO Over Run Clutch for 9N in reply to Pete H, 08-14-2000 20:38:08
Greetings:
I have one for my 8N that fits without modifying the threads for the cover, but you have to take it off to use the cover, because it is a tight fit. There was a fellow, John from Colorado, that was supposed to have a type that was a lot more compact and presumably would work with the cover, but I hven't seen a post from him for a while; sometimes he will e-mail people with questions about parts and point them in the right direction, or if he has a spare, will offer to send it to you for a reasonable price. I have found him to be very helpful and honest. Anyway, I got mine from central tractor, because I didn't know about this other one when I needed an ORC.
Good luck!
JOHN :>)
