Torquing axle nut
Russ in SoCal
08-16-2000 11:38:53
Re: Recent dicussion on 450 lbs/feet on axle nut. Here's a link to Harbor Freight socket sets. The second one listed looks like it oughta work. Personally, I think I'd go to Sears and see if I can buy the one socket. Been my experience that Harbor Freight gets good anvils and sledge hammers from China. Everything else may or may not be so hot.
Russ
Ed Gooding (VA)
08-17-2000 06:35:56
 Re: Torquing axle nut in reply to Russ in SoCal, 08-16-2000 11:38:53
I bought the Harbor Freight 3/4" and 1" socket/ratchet/breaker bar sets when I first got my 8N and quickly discovered that my quality 1/2" socket set wasn't gonna cut it. When I first opened the box, I thought "uh oh, wonder if these will be breaking on first use?" Snap-On they ain't. So far, the tools have done everything I've asked of them with no problems. I figured the cheap looking ratchet would be long gone, but it's still kicking. I wouldn't want to try to make my living with these boys, but for occasional use, they seem to do fine.
Hope this helps..... ..... Ed
'52 8N475798
fessman
08-16-2000 17:13:25
Russ,
I have the set from harbor freight and it works great. I've used it on the bush hog, axle nut, lug nuts, tow ball for the truck.... In addition to the set I got the breaker bar approx 25" and a adapter for 3/4" to 1/2" (not from harbor freight) and they work great. The alternative is to buy a set from sears or snap-on, but it cost a lot more.
Fessman
AL@NC
08-16-2000 16:28:09
Just get a 4 1/2 foot cheater bar and a 100 lb scrawny teenager to hang off of the end of it.. ( not an original thought, read it here first a year or so ago )...
Claus
08-16-2000 14:25:08
Well, I have both. The socket from Sears was about $20.00. I also have the 3/4" set from Harbor Freight it costs about $44.00 for the whole set. Albeit, it is a little crude but if you do not do this for a living, it will serve your purposes.
Happy Motoring
Claus
Hendo
08-17-2000 05:57:20
 Re: Re: Torquing axle nut in reply to Claus, 08-16-2000 14:25:08
I bought a 3/4 drive set from CT 12, years ago, they were made in Korea, sockets to 2" ratchet & breaker bar, $35.00 they have been throuhg plenty and the ratchet is still holding, never split a socket either.
