Piston rings
Rick
08-21-2000 12:35:20
I have an 8N ford, I just received my new pistons and rings. On the two top compression rings they don't say which is top. They have a chamfer on the inside of the ring on one side only, does this go up or down??
gavin
02-26-2001 08:20:00
 Re: Piston rings in reply to Rick, 08-21-2000 12:35:20
the taperd one is the top one comprestion rings and make shure the std mark or over size mark faces down the beg end shell
ZANE
08-21-2000 18:55:17
I memorized this 40 years ago and it has always been right when I had a set of rings that was marked. The chamfer will always go----- ----
"inside up - Outside down"
Brent(AR)
08-21-2000 14:01:21
The instructions that came with my kit says "if there are no dots, bevel or chamfer goes up."
Brent
