Axle bearings -- using a brass drift?
rob 8N KS
08-22-2000 10:04:39
In the thread below, Roger mentioned putting on rear axle bearings with a brass drift and a hammer.
(IGNORANCE ALERT)
What's a brass drift? Is this like a punch?
Roger
08-22-2000 10:32:00
 Re: axle bearings -- using a brass drift? in reply to rob 8N KS, 08-22-2000 10:04:39
1/2" dia. brass rod - similar to a punch.
I didn't have much luck with it. I did a practice run on a junk axle/bearing taking the bearing off. Yea it worked but you have to be REAL careful not to miss and bend part of the bearing. The mechanic claims it works a lot better going on because you have a better angle and more surface area to work with.
Personally I wouldn't recommend it as anything but a last resort.
Just my opinion,
Roger.
