Hour Meter for 6V...?
Rich Z.
08-22-2000 13:32:17
I recently rebuilt my 8N and it is running like a top....thanks to some various help from this board.
I would like to put a meter on the tractor to determine how many hours I put on it after the rebuild. I have found a meter at my local NAPA, but it said it was only good for 10-32 volts. Are 6 volt meters available....I have not been able to find one locally.
Thanks in advance.
Rich Z.
08-28-2000 05:43:43
 Re: Hour Meter for 6V...? in reply to Rich Z., 08-22-2000 13:32:17
Thanks all.....
EDDIE
08-26-2000 05:33:55
CHECK WITH AN ATV/MCYCLE SHOP FOR A UNIVERSAL HOUR METER. I FOUND ONE AT A SHOP NEAR ME. IT HAS A TWO WIRE HOOK UP AND DOESNT CARE ABT VOLTAGE, IT HAS ITS OWN POWER SUPP;Y
Vic
08-23-2000 17:25:18
Most of these meters have a mechanical clockwork mechanism, and just use the DC voltage to keep the balance wheel ticking away. If you can't find a true 6 volt unit, it's probable that a 10V mechanical meter would operate and be accurate on a 6 volt system, which typically operates at something over 6 volts anyway.
I've used hour meters at half their rated voltage with total reliability and accuracy. Especially if NAPA would take it back if it didn't work, I'd give it a try.
One word of caution, though: if it's a Liquid Crystal display or other electronic digital display, it's obviously not a clockwork mechanism, and I have no idea if it would work OK.
Scott
08-22-2000 15:18:06
Just remember an electric meter will count the
time the key is left on even though the engine
is not running (even after it burns up the
ignition)
Claus
08-22-2000 14:45:58
See J.C. Whitney, they have one... 4 - 12 volts.
Happy Motoring
Claus
