Voltage at coil
Rick
08-25-2000 10:47:16
I just finished a complete eng. overhaul. I'm trying to start it now. I have 6.35 volts from the battery to the switch. from the switch to the "resistor" I have 6.35 volts. from the resistor to the coil I have 2.25 volts. I have no spark from the plugs. does anyone know what the voltage should be at the coil? It is a 47 8N 6 volt system. Thanks
