Carbouratorflooding
robert
08-26-2000 10:35:21
i have rebuilt my carbourator and ever since i have had problems with the float not shutting off the gas when the bowl fills.
Dell (WA)
08-26-2000 10:58:14
 Re: carbouratorflooding in reply to robert, 08-26-2000 10:35:21
Robert..... .Is this a trick question?
Obviously, carb flooding is caused by the float valve not closing. A float can be hung up on the side of the carb. It can also not pivot correctly. The float valve needle could have fallen off. The float could have sprung a leak and is now full of gas and no longer floats.
You've had the carb apart once, now you are up to speed on the learning curve. You will need to take the carb off and apart for an inspection, it should be eazier this time..... ..Dell
