Backfire
Ron
08-28-2000 10:43:12
Hey guys, I have a 49 model 8-n and Im having a little problem. I converted it to a 12 volt system. It ran good for a while then started backfiring and missing bad. I reset the points and cleaned them. It ran good until I started discing then started the same thing. I am going to put a voltage reducer in the line before my coil to see if that helps and check the points again. If this doesn't help do you have any suggestions? Thanks, Aggravated Ron
Claus
08-28-2000 11:12:24
 Re: backfire in reply to Ron, 08-28-2000 10:43:12
Backfiring can be caused by a variety of causes. BUt one thing that you said could also cause this problem. If you did not change coils and did not put a dropping resistor in series with the ballast. this could have runined your points and or coil.
Happy Motoring
Claus
