Zane, ? on your NAA post
Roger
08-28-2000 13:04:17
I was reading your post on NAA still won't lift.
You suggested polishing the unloading valve bore w/180 grit sandpaper around a dowel.
I have a 8N w/sticky exhaust valve. Is there any reason I should not hone the exhaust bushing as you describe? I've tried everything I can think of on the valve itself. I even tried a NOS part which made no difference.
If I try this and it doesn't fix the problem the only thing left I can think of is to have the original exhaust valve enlarged and machined to fit the bore better and cross my fingers.
Comments?
Thanks,
RT.
