Rear worklight
where to ground?
rob 8N KS
08-30-2000 08:54:24
I wired my headlights and wired them back to a good ground on the neg battery lead.
I want to add two rear worklights (got 'em CHEAP from the Oregon dealer going out of business!) do I really need to run a wire from the terminal block AND a good ground wire out to the fender? Or can I ground on the fender?
george s
08-31-2000 06:04:28
 Re: rear worklight - where to ground? in reply to rob 8N KS, 08-30-2000 08:54:24
If you want something tougher than the 2 lead lamp cord,marine suppliers have a 2 lead wire encased in a tough waterproof jacket that would make a nice, probably permanent job.
rob 8N KS
08-31-2000 06:08:37
 Re: Re: rear worklight - where to ground? in reply to george s, 08-31-2000 06:04:28
as a former Kansas boat owner, I've never been able to find anything that marine suppliers are supposed to carry.
Shoulda seen what I had to go through to find Marine-tex
Ever seen these marine leads mail order?
Mike OH
08-30-2000 18:17:10
I recently mounted a tail light on my Jubilee. I ran two #14 wires from the light to light switch area. I then connected one wire to the switch and grounded the other up under the hood. Both wires were run thru shrink sleeving which made a nice neat cable and offers additional protection to the wires. Mike OH
Gaspump
08-30-2000 17:59:01
Grounding of lights on restored or repainted tractors usually is a problem due to the fact that most people paint the originally plated light bases, bolts and swiveling parts thus insulating them from the metal contact that was originally intended. Also the better quality of the repaint coverage insures that there is no continuity passing thru. On my working tractor I grounded the headlights by making a new ground wire for the light that runs thru the attaching bolt and is secured by one of the dog leg bolts. The work light ground wire is attached to the back side of the work light bracket bolt. Also because the painted fenders and axles are not condusive to a good ground I put star washers between the axles and fenders to make good contact. Makes for good bright 6V head lights and work light.
Bill(NC)
08-30-2000 16:33:46
If you don't want to run a ground wire, you might consider putting a ground strap from the fender to the cast axel cover (don't know the official name).
Dell WA)
08-30-2000 11:36:43
Rob..... ..Its really not a bad idea to provide a ground. I'd at least look at using some stranded 14 ga twin lead zip cord from the local electrical hardware store..... ....Dell
Salmoneye
08-30-2000 09:57:29
I grounded my 'tail' lights to the fender, but after about a month, I had to loosen and turn the bolts that hold the fenders on to reestablish a good connection.
Bob
08-30-2000 20:14:23
 Re: Re: rear worklight - where to ground? in reply to Salmoneye, 08-30-2000 09:57:29
I had the same experience as Salmoneye. My light, which was grounded thru the mounting bracket, worked fine for a while. After a couple of months, it started to flicker and get dim. I connected a test lead to check the ground, and sure enough, it was bad. I'll be running a separate ground wire to correct the problem, I should have done it when I first installed the light.
