A calm old 8N/ side mounted distributor converted to 12 volts by unknown previous owner, with several years of road blading and snow removal without incident has become haunted when attached to a King Cutter brush hog, esp. on rough ground.It stops suddenly and won't start sometimes for hours. Have tried tapping on carb which seems to help sometimes and most always will start after removing the distributor cap and replacing it. At times it shows weak or non existant spark. Have eliminated the vapor lock theory from comments received on this board, but we do have 10% alcohol in our fuel in Minnesota. Found rust in the gas tank and regular sediment in the glass bowl under the tank. Which I had suggested to me could clog the main jet especially if tractor was going over rough ground. Followed intial advice and replaced: ignition switch, coil, points, condensor and installed new resistor. Both I and mechanic checked voltage to the coil and from the coil. Seems to be within specs. Points are not pitted nor blue. Distributor has been checked by two mechanics which is "O.K." Primary wire connection though the side of the distributor has been cleaned and appears o.k. Implement dealer could find nothing wrong with the ignition, or anything else for that matter. They installed a new inline fuel filter (which doesn't affect power) and sand blasted the inside of the carb bowl as it showed some flaking? Next series of events was to remove and replace the fuel tank and remove all electric connectors and sodder all connections. Put in new plugs when I had the cover and tank off. Also checked all wires - not many, and they seemed fine. Tractor ran fine until hit first golpher mound with brush cutter and it killed. Got it started and it ran and killed, ran and killed and then wouldn't start. Tapping carb seem to help keep it running for a while. Had supper and did excorism routine which included tapping side of carb with no results and then removed and replaced distributor cap and got immediate start up. Put in garage. Next steps rebuild the carb (which seems to operate fine and was cleaned and adjusted by the implement dealer. New distributor am running out of things to replace????? ????? Only thing that correlates with the immediate stopping is hitting a golpher mound, rough ground or hitting a jostling bump - all this in 1st gear at 1/2 throttle? Only consolidation is my neighbors 9N does the same thing with her brush hog. I'm running out of money and patience. Is their something that I'm missing? I am not usually a total failure at fixing mechanical things. This tractor is simple? Is the PTO connected to the governor and then to the electrical system. No I didn' think so!~ Ideas or does somebody want to buy a nearly new tractor that quits occasionaly. My neighbor says its a female tractor and I need to live with it??
