Order Ford 9N Parts Online
Compression on 9n
s.speer
09-01-2000 21:43:08
Hello I am looking to find out what the compression should be when running a compression test..or at least what is acceptible..thanks for your time..
Dell (WA)
09-01-2000 22:26:03
 Re: compression on 9n in reply to s.speer, 09-01-2000 21:43:08
Speer..... ..minimum 90 psi per the I&T FO-4 manual, 5 strokes and record the reading. Check for both dry and wet. More important than 90 psi it relative equal compression across all 4 cylinders..... ....Dell
