First things first. What kind of 12v coil do you have Internal or External Ballast (should be stamped right on the coil. If it is an Internal Ballast coil, then you will/should have 12v at the BAT side of the coil directly from the keyswitch all the time the switch is on. The internal resistor inside the coil will automatically reduce the voltage to the coil windings sometime after you start your engine. (It's a thermal thing, you supply power, it heats up & changes resistance, hence current to the coil.) If you have a coil marked External Ballast, you MUST have a ballast resistor wired in series from the keyswitch to the BAT connector on the coil. If you do not have the ballast resistor in series with the 12v from the keyswitch, you will fry the new coil in a matter of several minutes. Some have successfully used the resistor behind the tractor dash as a ballast resistor for coils marked External Ballast. Be sure to check the wiring between the points and the distributor. Install the dist, and connect your voltmeter to the Points side of the coil. Rotate the dist by hand (or bump the starter) to get the points open. The voltage at the connector should be around 12v (6-12v is fine). Now rotate the dist so the points are closed. The same connector should read 0v. Anything else and the points or wiring are suspect. By the way, grasp the dist shaft and try to rotate it. If it rotates freely, the distributor drive gear is broken. (But then you already checked for that, didn't you?) When you are checking for spark, remove the spark cable from the central tower of the dist cap. Hold it with something insulated (plastic pliers, etc) and place the free end in close proximity of the engine block (1/8" or so). Keep it away from the fuel line. Crank the engine with the key on. A good spark verifies the coil. Reinstall the coil lead in the dist cap. Now remove one of the spark plug wires from the dist cap. Insert a spring-clip lead in the hole in the cap, and holding the free end of the jumper with something insulated close to the engine block, crank the engine as before. A good spark here verifies the rotor. Now hold the same lead close to the spark plug. No spark here means the plug is not firing. It may be gapped wrong, the spark may not be hot enough, who knows. Reinstall the plug wiring into the dist cap. Remove the spark plug, reattach its wire from the cap. Rest the side of the plug against the engine (good ground) and crank the engine with the key on. This will test the plug. Hope this helps. Let us know the results. Don8NAZ
