Order Ford 9N Parts Online
9n wont start
robert ball
09-04-2000 04:15:59
i hosed off my tractor several weeks ago. It would not start after that. I changed the spark plugs and spark plug wires. It finally did start however it didnt start as easy as it usually does. The next two days it did start until it rained. Once again it wouldn't start. We then changed the condenser, points. rotor and rotor cap. It still makes no attepmt to start. I tried spraying it with wd40. Nothing I changed the coil it still makes no attempt to fire
Larry
09-04-2000 04:54:26
 Re: 9n wont start in reply to robert ball, 09-04-2000 04:15:59
It sounds like the distributor cap to me. Try spraying inside the cap with wd 40. It has great moisture displacement properties. The cap may need to be replaced if rain or other moisture seems to affect it.
