Order Ford 8N Parts Online
STEERING BOX ON 8N
PAUL
09-04-2000 16:55:22
MY STEERING WHEEL HAS STOPPED TURNING. IF IT DOES MANAGE TO TURN IT UNSCREWS ITSELF UP. WHERE TO START, I AM ROOKIE TO TRACTORS AND HAVE ONLY HAD THIS ONE A MONTH. HAVE GOOD MECHANICAL SKILLS AND NEED RECOMENDATION FOR MANUALS TO COVER ALL REPAIR AND MAINTENANCE ON 8NS. THANKS
Claus
09-05-2000 04:09:08
 Re: STEERING BOX ON 8N in reply to PAUL, 09-04-2000 16:55:22
Replace the upper thrust bearing. Stay away from the cheap teflon ones and get the steel barrel bearing about $13.00..While you are at it inspect the lower one too.... When you reassemble, you do not want more than .010 play in the vertical shaft movement. This is controlled with shims between the base and the shaft tube assembly...
Happy Motoring
Claus
NCN in Tx
09-04-2000 20:01:38
Get the I&T manual from FNH or one of the vendors advertising on this site. Chances are that the upper bearing has failed on the steering shaft and that can be easily and inexpensively replaced. It's typical of an upper bearing failure if the tractor will only steer one way or if the wheel and shaft seem to worm their way out of the shaft housing.
It sounds like this is your problem and is likely due to loss of lubrication. It's not a difficult task to fix and relatively inexpensive as long as the "ball nut" is still good.
Good luck with yours.
Niels
ray
09-04-2000 19:08:58
My steering froze up on my 8n. The mechanic said the seal - on the steering wheel shaft had let in rain through the years. Rusted the whole thing and it would only turn to the right.
A new gear box, gears etc and $800 poored and I was steering again.
ray
09-04-2000 19:08:28
Dell (WA)
09-04-2000 19:02:35
Paul..... ..get the I&T FO-4 repair manual $20 cheep. Good pictures, deacent instructions for newbees. Neat thing about these ol' N-Tractors, repair parts are relatively eazy to get and pay for. Check the "archives" at the top of the N-Board. Lots of references to steering problems. I'm over 50 yrs old and sometimes I don't steer to good eather (grin)..... ..Dell
Pat R
09-04-2000 18:11:57
An I&T manual well do fine for N series others? Joke (IT) stand for it may tell,it may not.
But anyway sounds like you may have some bad bearings in the gearbox or possible shattered sector gears?
Good luck
