Rear worklights, 2 questions, w/pics
rob 8N KS
09-21-2000 11:36:37
I have a set of these lights that I want to hook up as rear worklights.
I already have the fender brackets for each fender.
Two questions.
1) Where can I get some sort of swivel mount for the so I can move the lights around?
2) I assume the ground connects to the big mounting bolt and the lead from the terminal block hooks up to the smaller machine screw on the white plastic post?
Dell (WA)
09-22-2000 08:46:07
 Re: rear worklights, 2 questions, w/pics in reply to rob 8N KS, 09-21-2000 11:36:37
Rob..... ...I guess yer gonna' hafta' be ingenuous and invent your own kind of swiveling bracket. But why re-invent the wheel if someone else already has, right? You might check a marine supply house, an industrial equipment place, hospital equipment, an over-the-road truckers parts place, an RV place.
Ya' gotts the electrics figgered out, but with all the rusty joints on old tractors, I'd supply a separate ground wire anyways. Naturally, an in-line fuse somewheres too.
Dang.....thems good enuff lookin' lites, where did you find them and how much? if ya' don't minds my asking..... ..Dell
rob 8N KS
09-22-2000 11:16:34
 Re: Re: rear worklights, 2 questions, w/pics in reply to Dell (WA), 09-22-2000 08:46:07
I got them from the tractor supply place in Oregon that was going out of business. They were posted on here about a month ago.
I paid $5 each for them.
I have since opened them up to check out the wiring and I was correct in my first post.
Also the switch is high/low, not on/off.
They're made by Hobbs (put that in here so if someone searches in the future, they'll find this post.)
