When we first got a wood stove, we got a big ol' inefficient hunkin' used one. Got some 6" thin-walled pipe and cut, popped, and banged that together until, by golly, it went pretty much vertical with a jog up and over and connected it with the insulation (or whatever it's called) box at the ceiling. Well, the stove took 8" pipe, but I got a reducer. I should've stayed with 8" because.... The old stove worked ok, but if you had that puppy with a good hot fire dampered down real low, and opened the door too fast, to add wood, FAROOMPHTH! ...lots of smoke poured into the room and beeping of the fire alarm and kids running around yelling that the alarm went off and wife waving a kitchen towel or bath towel or big couch pillow at the alarm with the front and back doors open at 10pm when it's 33 degrees outside. Where's Norman Rockwell, when you need him? Well, we finally bought a new super duper gol dang brang spangler new efficient stove and had them guys come and install it for us. They used 6" thin walled pipe and screwed it together real tight. We burned something called "energy logs" (real big pellets...compressed sawdust) last winter, and while it was pretty neat...burns hot, you're recycling, @.85/log, it was probably 75+% more expensive than oak ($185/cord, delivered). The new stove is very efficient and allows you to damp the fire down to a blue flame, which is burning more of the gasses, rather than letting them go up the chimmney. Dave #1 asked about pellet stoves...everyone around here is turning them in (as well as wood stoves) for the very clean and easy propane stoves. Friends of ours have an older pellet stove. They can really burn efficiently. The fuel comes in bags you store someplace dry and is cheaper than oak cordwood, The exhaust is not too hot and is likened to a dryer (so I am told). Low ashes to clean up. Drawbacks...they need electricity to run the fan (batt. backup?). Astethetics are kinda low too since the flame is real small. They're also noisy. Well, good luck with whatever you do. The fire and CO2 alarms are a must, and I don't know how you would check the tightness of an old stove, but it shouldn't leak fumes/gas inside the house. I'm kinda obesssive here...no matter how cold it is outside, we usually keep a near window cracked for fresh air. (interesting ideas mentioned earlier re: vents in baseboards). If you go with that thin walled pipe, you might see how much it would be to have it installed professionally. As alluded to, resin-y woods create lots of crud in your chimney (note other posts re: cleaning regularly). If you have natural gas or propane available, there are lots of options too, and some new stoves don't need the clearance that older ones needed. Some even claim to be "ventless" not requiring a chimmney...???
