Incoming!
Sam (Mo.)
10-11-2000 08:14:01
I just spent a 3-day weekend bush-hogging the roads and food plots on our hunting property with a 5' King Kutter bush hog and my second-best 8N. (Deer Season approaches!) That's why I'm crippin' around with a softball-sized bruise and laceration on the outside of my left thigh and a baseball-sized one on my right calf, plus lots of smaller wounds. The Ozarks - Land of Flying Rocks and Stumps!
My son-in-law avoids all this by driving a big Farmall, which puts him too high to be hit. These Fords leave you down in the combat zone, though, and I have been thinking about making some kind of temporary shield.
Has anyone here ever built a shield that fits under the seat and flares out to the sides a little and down behind your legs? It seems like it would be possible to make one to attach only during bush hogging. Something out of metal or maybe even plywood? I'm sure I'd be walking better right now if I had done something like that. Lemme know your thoughts. - Sam
Dale O'9N
10-12-2000 11:57:24
 Re: Incoming! in reply to Sam (Mo.), 10-11-2000 08:14:01
You might try attaching a board there in front to deflect the projectiles down when they are launched. If the board is fastened to the frame of the bush-hog. Then hook a chain to the front of the board up to 3 pt arms or something. this will let it be adjustable to let it work best. You should also raise the hog a little more off the ground. If it is rocking back and forth to grab those missiles, you will need to stabilize the hog somehow. Always use the bars when bush-hoging. Be a little safer. Dale in VA.
Fred OH
10-12-2000 10:07:15
Theres always a Gallagher in every crowd! Go buy you or make you a suit of armor. Solves all your problems, including space junk falling out of the sky, drive by shooters, the 'ol ladies skillet, busted knuckles when your wrenchin and going to sleep and falling off the tractor.
Of course it must be OSHA approved :>)(<:
PS Downfall of above is: Hard to eat pork and beans or them water packed weinies while bouncing around on the tractor. They'd probably get all over the inside of the suit when that mask thingy fell down on your plastic fork. I'd suggest a thing to mount a couple of cans of Coors Light up on the helmet with a bullet proof straw.
On the other hand, you'd look cool. L8R----Fred OH
dave#1
10-11-2000 19:44:46
third party image
Been there,done that !
I remember the first time I got nailed in the back of a leg with a flying rock/stick, I had to get off my N and walk it off, ever since then if I'm hogging nasty stuff I put my feet up on the shifter cover. I've had the same thoughts of makeing some kind of a guard/shield, I'm think'n of useing a large piece of a pickup truck box mat, the're about 1/4"-3/8" thick, thought I could notch it to clear the lift arms and such, then just make something to mount it that would'nt be a song and dance to install/remove.
Might be something to think about?
later,dave
Rusty 2N
10-11-2000 18:58:30
Heavy rubber conveyer belting & I'd use heaver then 1/8 in steel.Maybe angle iron. Over build is the key to this farmin' thing. Good luck.
Jim (MO)
10-11-2000 17:16:10
Kingkutter, www.kingkutter.com, lists front & rear chain gaurds as available accessiories
Charlie in TX
10-12-2000 07:23:46
 Re: Re: Incoming! in reply to Jim (MO), 10-11-2000 17:16:10
I went to there website and could not find the accesories page. Would you give me a little more info on how to get to these chain gaurds?
Jim (MO)
10-12-2000 08:15:25
 Re: Re: Re: Incoming! in reply to Charlie in TX, 10-12-2000 07:23:46
Charlie, The page seems to have changed some since I looked at it several months ago. Now if you go to Products/Rotary Lift Cutters it just mentions them as being available. I'm sure before there was a link to a little more info and they were priced at $129.95 and had to be special ordered from a dealer if not in stock. Kind of expensive!!
Later, Jim
raytasch
10-11-2000 13:26:46
Old truck mud flaps make a satisfactory trash shield. After getting hit with a piece of trash and thinking I had broken a rib I fabricated a shield from a flap. Mine is fastened over the top link and tied down to the lift arms. I am not that concern about my legs as I am about my head and back. ray
Charlie in TX
10-11-2000 11:53:55
This is one thing I don't like about my King Kutter. The deck is so short in the front that the blades are exposed. It appears that if you install chains, the chains would hit the blades. I am going to weld on an 6 in extention of 1/8 in steel to the front. I will hang chains from that. The chains will stop all that big stuff flying out.
Salmoneye
10-11-2000 10:29:48
I have been thinking about a front chain guard for my 5 foot King-Kutter, but till I get one, I wear my 'wood-cutters helmet'.
The helmet is a hard-hat with 'ear muffs' and a flip-down face shield. The face shield is 1/4" mesh and will stop a lot of stuff.
I don't know about others, but the 8N with a 'hog' is darn loud and I appreciate the hearing protection...
Larry 8N75381
10-11-2000 10:07:44
Sam,
How 'bout taking some all-thread and making two "U" bolts to fit around the axles on both sides. Then take some flat cardboard and make a pattern that fits between the fender and Diff. housing and is on the front side of the axle. The bottom end should be just below the back edge of the running boards, top end high as it can be without inerfering with the lift or whatever. Or you could notch the upper end so that it fits around the lift arms. I'm not where I can run out and look at my 8N to see how this would work out, but I'm sure you can figure something out.
The patterns then can be used to cut a piece of plywood or heavy sheet metal as your shield. The U bolts would hold the shield in place on the axle. You will have to fit a spacer to the U bolts to keep the shield up off the brake rods that run along the front of the axle. I'd also fasten the shield to the running board some way. If you use plywood, you could wrap some carpet (remenants) around the edges and staple them to the plywood. This would protect the paint on the fenders and differential. Guess you do the same for a sheet metal shield using bolts and strips of metal to hold the carpet in place.
You'll have to post pictures and plans for your final solution. Then Dell can add that to his "sermon" on bush hog safety using an ORC.
HTH
I use my 3000 to bush hog, but then I sometimes run down and cut up 2" trees. NOT something I'd try with a 8N. Besides I couldn't bear to mistreat my Uncle's 8N that way. It is susposted to be the "family heirlom" that is passed from me to my son and then to his son (now 18 mo.). I hope he will do his "first" driving on the 8N, like I did. :-)
Larry
Dell (WA)
10-11-2000 08:24:58
Sam..... .I'd sure 'nuff look into riggin' some sort of "chain curtain" shrapnel catcher around the lip of the brushog like the highway depts have on their brushogs. I have a friend who lost his dog to a launched object out the side of his brushog. major bummer..... .Dell
TimK
10-11-2000 09:00:23
 Re: Re: Incoming! in reply to Dell (WA), 10-11-2000 08:24:58
I just bought a new Bush Hog brand bush hog. They offer a rubber/plastic curtain to bolt to the front of the hog. Probably would fit other brands.
