Can Front axle be welded?
rod
10-12-2000 17:24:35
I bought a salvage tractor and while taking it apart discovered the front axle had been welded on one side by the pivot pin hole and has recracked. Can this be successfully repaired or should it just be tossed out. It looks like it was welded while still on the tractor at the top but is now cracked down about 2 inches. thanks
rod
Truck
10-13-2000 06:14:58
 Re: Can Front axle be welded? in reply to rod, 10-12-2000 17:24:35
IF anyone can answer you, it'd be Steve from U.S.Alloys. He seems to hang over on the tool board just waiting for the tough welding questions.My guess would be yes.Post over there if you haven't already. I'd title the Post "How to weld axle forging???" That should get his attention.
