How do I test for proper power output
Peter
10-13-2000 14:58:02
I'd like to know whether I am getting proper power from my 8N. In high gear it has satisfactory speed, but only until you get to a slight hill. I mainly just plow snow, with a front blade, and in 2nd. If I can do the job with lower rpms and get adequate power, that sounds good. Much of the time I have to use 2/3 full throttle. Is there a way to test for proper operation of the gov.
Mad Max
10-16-2000 20:11:24
 Re: how do I test for proper power output in reply to Peter, 10-13-2000 14:58:02
Get a compression tester warm up engine... remove plugs and screw in compression tester into spark plug hole crank engine (in neutral) should have min 90psi in each cylinder and there shouldn't be more than a 25% difference between any of the readings. I don't know how to check if the govener is working properly, of course you can look and make sure the linkeages are moving freely.
