Trenching with a plow
Ted/Ga
10-13-2000 16:13:33
Hello Everyone.
I just read an article that was posted on this subject. I will attempt to dig an 18 inch deep trench to bury a water line this weekend. I have a plow, but I am not sure what kind it is. It is a fairly big one, about 2 1/2 feet long.
Do you think that it would dig the trench? My uncle, who gave me the plow, used it a couple of times, and doesn't need it. He said that it would dig with no problem if I dug, then laid the dirt over again that was beside the trench, and then dug again. It is a single plow.
I was also advise to refrain from using the draft control. My uncle said that they are easy to break. Any thoughts?
Dell (WA)
10-13-2000 23:11:19
 Re: Trenching with a plow in reply to Ted/Ga, 10-13-2000 16:13:33
Ted..... ...I'm assuming you are refering to this months "Yesterdays Tractor" Newsletter (sponsors of this great N-Board).
The "secret" to using the plow to dig a trench is to "shorten" the 3-point" top link. Normally, you want the plow share to be "flat & level", in this case you don't. you want the plow to "dig in" by shorting the top link.
You will need to make several passes to dig it 18" deep and that is O.K. Normally, a plow only digs 4-6" deep and turns the slice of dirt on edge. In this case obviously, you want the plow lifting the dirt out of the furrow with the moldboard.
I'm sorry, I would have to respectfully disagree with your uncle and state that I would definately plow in "draft control". Your N-Tractor is designed for that. Place the little handle in the horizontal position for draft control and plow away.
And from just having to dig up my well pressure line to repair a leak. I have NO NICE WORDS for anyone that burys a pipe with out "bedding" it in "sand". The SOB just covered the plastic pipe with boulders, well rocks the size of baseballs, that eventually punctured the plastic pipe. grrrrr!!!!! ..... .Dell
Ted/Ga
10-15-2000 15:51:13
 Re: Re: Trenching with a plow in reply to Dell (WA), 10-13-2000 23:11:19
Dell,
I set the plow up today, and we dug a very nice "experimental" trench at the back of the property next door, that the real estate company is still trying to sell. Hey, why go around trenchin' up my place? (grin)
I shortened the top link as much as possible on this rather large International brand plow, about 4 or 5 passes, and you could almost but a body in the 14 or 16 inch hole. We are going to run heat tape with the pipe, just to be sure. Thanks for the help. Ted/Ga
hey busdriver
10-14-2000 22:29:15
Dell, I know sometimes some things are done without thinking of the consequencs. I bought my home from my father-in-laws estate. 25 years ago he planted a cute little monkey tree only a foot and and half tall , right in a nice spot on the front lawn. 25 years later it is 30 feet tall ,I had to replace the water pipe right underneath it, I quess that's why they say hind sight is 20/20. As for putting rocks in the hole , you would wonder where they all came from, I filled the hole with the dirt and the rock and still had to find room elsewhere to get rid of the rest.
Stan
Dell (WA)
10-14-2000 23:35:34
 Re: Re: Re: Trenching with a plow in reply to hey busdriver, 10-14-2000 22:29:15
Stan..... ..you had dirt left over???
humm....Everytime I dig a fencepost hole (1) the biggest rock is always at the bottom of the hole, just off to the side and (2) ya' never have enuff dirt left over to fill in the hole after you plant the fencepost.
The ol' farmer, when asked by his city cousin, how he got so many rocks out in his field, he replied "first, ya' plants these lil 'uns and then when they gets all growed up, ya' harvests 'em"..... ...Dell
Ted/Ga
10-14-2000 05:51:03
Dell,
Thanks for your sage advice. I wouldn't have thought to tip the plow upward. Also, I took his storey about breaking the draft control with a grain of salt. He has been told this repeatedly by the guy who sells his equipment.
Now, and this is no joke, he has another, smaller plow that he has had for 10 years. During this time he has insisted that his rather heavy wife, who is really a sweetie, stand on the plow to hold it down, while he turned the garden. I told her about the draft control while we were looking at their tractor. She in turn told me the story about standing on the plow. He came home, she quizzed him about the draft control lever, he in turn relayed the story about how it would break...what else can I say? (grin) - Ted
Bill (Tx)
10-14-2000 06:54:46
 Re: Re: Re: Trenching with a plow in reply to Ted/Ga, 10-14-2000 05:51:03
What a trooper that wife is. I'd use mine like that but she only comes in at about 120 lbs and I know she wouldn't like to get dirty.
