Sway braces
Rick in Ut
10-13-2000 17:15:41
Last week I asked about the sway braces for an 8N. Now, Does the attatch point below the axle/fender mount bracket have to be the same height and "even" with the lift arm mount? I have a bracket below the axle using the fender mount bolts, but there is no hole, I guess the hole has to be across from the lift arm mount, but does it have to be the same height or can it be higher than the lift arm mount? Thanks for any information. I did get a response with a picture of the mount and arm from Rob 8N KS. I can't tell if the two mounts are straight across from one another.
Jim K
10-13-2000 17:46:53
 Re: sway braces in reply to Rick in Ut, 10-13-2000 17:15:41
Rick If you go with two bars your mounting pins have to be in line with the mounting points of the lift arms or you will get binding when raising or lowering the lift.If you only use one sway bar your mounting point doesn't have to be perfectly in line.
Jim K
