Points burning quickly
41_9n
10-14-2000 14:16:06
my 9n has the original 6v system and has just recently started burning through points quickly.
What might cause this?
Bill
10-15-2000 10:27:48
 Re: points burning quickly in reply to 41_9n, 10-14-2000 14:16:06
There are two things I can think of that will cause points to burn quickly.
1> They are misaligned (something gets bent when you install them)
2> Oil on the points. Clean your feeler gague with solvent before setting points. Check the inside of dist housing for excess oil. Don't overlube distributor cam.(Just a light film)
P.S. There is no resistor in series on a 6v 9n coil.
tOTG
10-14-2000 14:56:40
If your resistor has been bypassed and the points are getting 6+ volts they will burn quickly. A running tractor should have less than 4 volts at the coil.
John.CO
