Another pump question/ Zane, please help
Old George
10-14-2000 21:49:55
Zane,
Back on January 07, 1999 you wrote "On some of the very early pumps their was a longer pressure relief valve than the later ones and it had to be removed to clear but I don't think you are likely to encounter one of those because the relief valve is one of the parts that must be replaced periodically. Zane"
How can you tell? I am trying to remove my pump and I have the lift cover off, the PTO shaft removed, the 9 cap screws removed and the darn thing still won't come down. I can't hardly believe how stuck some parts can be on this old tractor. Can you steer me in the right direction so I don't break anything else. Thanks in advance!
Alan Esch
45 2N 183513
ZANE
10-15-2000 10:05:25
 Re: another pump question/ Zane, please help in reply to Old George, 10-14-2000 21:49:55
Do you have the gasket seal broken loose on the pump to the housing?
What model tractor do you have? The 9N and 2N have a double wish bone control rods that must be disengaged fromt he pump control valve T or you will break it when you drop the pump out. If it is a 9N or 2N you will have to remove both the side inspection plates so that you can pull the two rods apart in order to release the T on the control valve. Look up into the oil drain hole in the pump and you will be able to see the "T" that I am talking about.
