FUNK 6CYL
BOB
10-15-2000 14:10:16
GOT TRACTOR STARTED TODAY, MY QUESTION IS WHY DOES THE 6CYL NEED A FUEL PUMP OR CAN IT WORK THE SAME AS THE 4 CYL. THANKS GUYS
Claus
10-15-2000 14:30:00
 Re: FUNK 6CYL in reply to BOB, 10-15-2000 14:10:16
The reason the 6 cyl has a fuel pump is because it was not designed for tractor use with the overhead fuel tank and had to pump the fuel out of the fuel tank. I would prefer the fuel pump because if somthing goes haywire with the carb, you could loose all your fuel. There is no reason why you could not use gravity feed though.
Happy Motoring
Claus
