Order Ford 8N Parts Online
Voltage meter 8N
Rick in UT
10-15-2000 18:55:45
I have an 8N, typical voltage meter where the wire has an inductive pickup. Well, the voltage indicator is broken, how do I hook up the new volt meter with the two poles? Do I just cut the wire into and attatch one end to each pole? Or is there something else that I need to do? Any help would be great.
Thanks
Rick
STUMP PULLER
10-15-2000 19:13:17
 Re: Voltage meter 8N in reply to Rick in UT, 10-15-2000 18:55:45
WHAT YOU HAVE IS AN AMMETER. THE OLD ONE WAS INDUCTIVE PICK UP THROUGH ONE WIRE LOOP. YOU HAVE TO CUT THE WIRE LOOP AND CONNECT ONE WIRE TO ONE TERMINAL OF YOUR NEW AMMETER, AND THE OTHER WIRE TO THE OTHER TERMINAL. IF THE METER SHOWS DISCHARGE WHEN YOU TURN ON YOUR IGNITION YOU WERE LUCKY AND GOT IT RIGHT THE FIRST TIME. IF THE METER SHOWS CHARGE + YOU WILL HAVE TO REVERSE THE WIRE CONNECTIONS. GOOD LUCK.
