Order Ford 8N Parts Online
STEERING BOX CHANGE 8N
PAUL B. HORNIK
10-19-2000 04:07:44
IF CHANGING FROM OLD STYLE TO NEW STYLE STEERING BOX DOES ANYTHING ELSE HAVE TO BE CHANGED?
Mike 8N
10-19-2000 09:21:56
 Re: STEERING BOX CHANGE 8N in reply to PAUL B. HORNIK, 10-19-2000 04:07:44
If you have it out don't forget to add a zirc fitting and fill the new box with grease instead of oil after cleaning it out well. I just rebuilt my box, and added two fittings for grease and it works great. I rebuilt it because the upper bearing was toast from lack of lubrication and I had the newer style box with no way to add oil. Good luck.
PAUL
10-19-2000 06:17:52
THANK YOU FOR ALL THE INFO, DOES ANYONE KNOW WHAT THESE TRACTORS COST NEW BACK THEN?
Ed Gooding (VA)
10-19-2000 10:55:40
 Re: Re: STEERING BOX CHANGE 8N in reply to PAUL, 10-19-2000 06:17:52
Hi Paul: Click here to see the original invoice for my '52 8N
Regards..... ..... ..... .Ed
'52 8N475798
Ed Gooding (VA)
10-19-2000 10:53:28
'52 8N475798
Brentd
10-19-2000 04:55:16
I have to disagree mildly with Rick. I too just changed an old one for a new one. You need the new arms that go with the new box, and that necessitates getting a new dash as well because the clearance down at the bottom of the dash is different.
Brent
BB Stacker
10-19-2000 05:41:26
 Re: Re: STEERING BOX CHANGE 8N in reply to Brentd, 10-19-2000 04:55:16
I have also just changed my box out, and yes you do need to change the arms but I was able to use the original dash. It is bowed out about 1/4" at the bottom, but this causes no problem. I was able to run it down the road in 4th gear and the sherman in high for the first time. The gear ratio in the later box is better than the early ones and steers much easier.
Brentd
10-19-2000 06:13:12
 Re: Re: Re: STEERING BOX CHANGE 8N in reply to BB Stacker, 10-19-2000 05:41:26
Yes that's right. You can force the old style dash. The other option is to cut some metal away or grind it off I suppose.
Brent
Rick
10-19-2000 04:33:40
I just changed one for a gentleman, he had the old style and I got a used "adjustable" one and installed it on his 48 8N. It fit great. I need nothing else to do to it.
Rick
10-19-2000 04:33:39
