Oil Contamination
Arnold - MD
10-20-2000 07:42:53
The oil on the dip stick on the rear end turned a light brown recently. I also noticed a light brown in the engine oil. I changed the engine oil, and it turns light brown again. When the oil is drained from the engine there are streaks of light brown.
Are there any thoughts of what the source of the contamination is?
I recently replaced the radiator. The old one was clogged with raditor leak preventer, and was beat up.
Steve W
10-20-2000 08:00:13
 Re: Oil Contamination in reply to Arnold - MD, 10-20-2000 07:42:53
Both cases of oil turning brown are from water contamination. In the rear end, it is usually the shifter boot leaking in the rain. Cheap fix.
The engine is another story. If it's cold outside, and you don't let the engine properly warm up, condensation can cause a slight milky color....that is why it is reallly bad to start an engine sitting in storage every couple of weeks to charge the battery!
More likely, it is a leak in the head gasket, allowing water to go from the cooling system, to the oil....is the radiator fluid disappearing? Could it be that someone added radiator sealant in the past to fix this problem, and in turn crudded up the old radiator?
The good news, is that replacing a head gasket is a lot easier on a flat head, but I am pretty sure you'll need to remove the hood. A torque wrench, a sevice manual, and a metal gasket is about all you need. Many people will have you check the head for warp, I think this is unneccesary. As master N mechanic Zane says, with 55 pounds of torque on all those bolts, it could be bent up like a potato chip, and you'd still flatten it.
Good Luck
Steve
Arnold - MD
10-20-2000 09:17:49
 Re: Re: Oil Contamination in reply to Steve W, 10-20-2000 08:00:13
Thanks.
With the amount of stop leak in the radiator I'm sure someone was trying to quick fix something. I thought it was the radiator since some of the tubes were pinched closed where it looked like a branch or something went through the radiator.
I was not sure if it was possible for the stop leak to plug a crack in the block. There is an old 12 inch weld near the engine block drain cock. This did not concern me when I bought the tractor. I just figured someone had a hard freeze before they could get out in the field to drain the water. I have seen similar welds on Model A's and other vintage cars.
I can't say for sure the coolant is not going down. When I start the engine I only let it run a short period of time, afraid I might fry the crank/mains. However, it seems to have been at the same level for the past 10 days.
I've been looking for a reason to pop the head off anyway. It will be interesting to see what else might be needed in the future.
