Follow up on no spark
roger
10-23-2000 09:33:52
First i want to thank ya for the replies.Now i know what to look for.Now, the next thing is,the wireing on my 48 8n. I'll start with the switch. I have 3 wires here.{1}Lead from - side of amp gauge to bat side of ignition.{2}wire from bat side of ign to starter selonoid.{3} wire from ballast res to ign.{4}Wire from coil to ballast res.{5}Wire from start button to plugin on starter selonoid.{6}One wire from alt to + side of amp.The lights were direct hook to bat through a toggle switch.There are 2plugins on alt but are'nt hooked up.Can any one(in plain english)tell me how to run the wireing as to how it is supposed to be??The alt is a Oj25??Also i assume that since ther is a ballest res that i have a 6 volt coil???If i went to a 12volt coil would i do away with the ballast res??I will be picking up all new wireing and coil&points in the next couple of days so any help would be appreciated. I have no clue when it comes to wireing(as ya gussed)!!Got to go and plant some trees.Dirt i understand!!
Wes
10-23-2000 12:09:47
 Re: Follow up on no spark in reply to roger, 10-23-2000 09:33:52
The wiring diagrams at the web site below may be helpful. They show the wiring for a 6-volt system and a 12-volt system. The diagrams are found near the bottom of the page.
