Upper Steering Housing Holes
Old George
10-24-2000 16:10:47
Gents,
This 2N has two "pea size" holes in the upper steering housing on the flat spot above where the solenoid attaches. Suspect they were caused by leaking battery acid. Just wondered if this is a common happening and if so, what method was used to repair? Thanks!
Alan Esch
452N 183513
Tyler (MD)
10-25-2000 03:36:01
 Re: Upper Steering Housing Holes in reply to Old George, 10-24-2000 16:10:47
Alan,
How's bout a little JB Weld. That'll plug the holes. It's good stuff.
Tyman
Old George
10-25-2000 16:55:20
 Re: Re: Upper Steering Housing Holes in reply to Tyler (MD), 10-25-2000 03:36:01
Thanks Tyman, I think that should work. Mostly I was curious how common the problem is with the battery mounted above? Based on the lack of responses I guess not too. :-)
Alan Esch
45 2N 183513
rbell
10-25-2000 05:30:52
Hey Tyler, is it true JB weld has a special type for aluminum? My son needs to fix a timing chain cover from a toyota truck and someone told him to get the JB for aluminum.
