Order Ford 9N Parts Online
Correct voltage at coil-9N
Radar
10-25-2000 07:09:53
What should the correct voltage to ground be at the coil primary connection? I know the ingnition voltage is reduced at the resistor terminal block but I don't know what the OHM value of that resistor should be.When I measure the volts to ground with the ignition switch on I read 1 volt- Is this right? The service manual I have says the voltage drop should be .3 volts but does'nt make it clear where the reading is taken.
I know the problem is primary wire to coil or perhaps a bad coil- I just don't want to "change parts" till I stumble onto a fix.
Thanks for any insight or info--Radar
Claus
10-25-2000 12:21:27
 Re: Correct voltage at coil-9N in reply to Radar, 10-25-2000 07:09:53
third party image
First read the voltage at the terminal block (6 volt junction) These readings are taken with the points closed. You should read approximately 6.3 volts. Then go to the other side of the ignition switch (Igntion switch wire and right side of ballast resistor.) The voltage should be 6.3 volts here also. (Sometimes old ignition switches drop a volt or 2 here due to crud on the contacts.) Then move to the other side of the ballast resistor and you should have between 3 and 4 volts here. (same as the top of the coil...)
Happy Motoring
Claus
Dell (WA)
10-25-2000 07:44:14
Radar..... ...the frontmount ignition coil terminal should read about 3.5 volts (3 min, 4.5 max) with the points closed, battery voltage with the ignition points open. Any other voltage is going to give you sparkie problems.
1 volt at the coil terminal is MUCH too low. Don't forget the possibility of a "bad" ignition switch.
Unless you have "lab grade" ohm meter, it will be difficult to measure the less than 1 ohm value of eather the ignition coil or the "ballast resistor". But even a cheepy voltmeter is accurate enuff to measure 3 - 4 volts. This is why we tell those with FMD to measure the coil input terminal voltage.
The infamous ballast resistor is mounted on the backside of the dash panel and automagically changes value with tempature, about 0.5 ohms cold, 0.7 ohms at operating temp. This is Ford's way of providing a "hotter" spark at start-up and tapers off the coil current to about 3 amps during normal running. If your coil is drawing too much power (amps), it will melt the insulative tar and shortout some of the coil turns and reduce your sparkies and your engine will run crappy or not at all..... ..... Dell
Radar
10-26-2000 11:41:44
 Re: Re: Correct voltage at coil-9N in reply to Dell (WA), 10-25-2000 07:44:14
Thanks for the comments fellas. Some times you got to know what "normal" is to gauge if a part is working ok. This tractor went into the pond recently (yes -I know how to adjust the brakes :-), that's next- after we run again) and the ignition got soaked. I am thinking that the problem nay be in the ignition switch. Again thanks- and stay away from water LOL
Charlie in TX
10-25-2000 07:24:15
I don't have experience with the fmd but I believe the voltage should be 3v with the point closed.
