Order Ford 8N Parts Online
8n rear axle hubs
Rick
10-25-2000 19:56:38
Need to remove both rear axle hubs. Have done this before, but, it's been a few years. The hubs are set tight and could not be removed with a medium-sized gear puller. Will get a larger gear puller tomorrow. Meanwhile, is there any secret to hub removal that might make it a little easier. Thanks in advance.
Charlie in TX
10-26-2000 11:20:27
 Re: 8n rear axle hubs in reply to Rick, 10-25-2000 19:56:38
If you are talking about the brake drums, you probably need to adjust the brake adjustment down to 'shrink' the brake pad od. In automotive aplications, the pads will make grooves in the drums. The pads wear into the grooves and lock the drums on.
Scott HouTex
10-26-2000 10:04:55
Check the archives for this. I seem to remember
a suggestion to loosen the nuts and drive the tractor around, in sharp turns, to help loosen
the hubs.
