Why is NAA lift piston better than 3 ring N piston
rod
10-28-2000 06:06:29
I am jsut curious why I have seen several posts recommending the O ring NAA lift piston is it better than standard 3 ring lift piston?
regards
rod
Steve IA
10-28-2000 06:46:57
 Re: Why is NAA lift piston better than 3 ring N piston in reply to rod, 10-28-2000 06:06:29
If the rings wear and break on the metal 3 ring older type, the cylinder can get scratched and may need to be honed or replaced. With the rubber o ring NAA style, if the ring breaks, all that happens is you leak oil past the ring. No damage done. Replace the o ring and off you go. Is it worth the price? If you gotta replace a damaged cylinder anyway, might as well replace with the NAA. If your old ram and cylinder are in good shape... You decide?!? . HTH Steve 8N 169302
dave#1
10-28-2000 07:57:39
 Re: Re: Why is NAA lift piston better than 3 ring N piston in reply to Steve IA, 10-28-2000 06:46:57
third party image
Yep, plus I think the "O ring piston" may seal better than the steel ring piston.
later,dave
Rick Zundel
10-28-2000 18:06:10
 Re: Re: Re: Why is NAA lift piston better than 3 ring N piston in reply to dave#1, 10-28-2000 07:57:39
OK, I have a 47 8N, what do I have to order? I have the 3 ring piston type and would upgrade while I am fixing the piston. I order from Farm & Country, but I didn't see one there. I have to order the complete eveything???? or do I just need to replace the piston and It will work in my existing cylinder? Let me know and I will get one ordered. Thanks
dave#1
10-28-2000 18:57:34
 Re: Re: Re: Re: Why is NAA lift piston better than 3 ring N piston in reply to Rick Zundel, 10-28-2000 18:06:10
You want to buy the "NAA piston and O ring", I bought mine from New Holand, don't remember the cost but was,nt to bad.
later,dave
