Order Ford 8N Parts Online
1950'ish 8N side mount timing gear
Barbara
01-26-2002 15:55:32
I posted on wrong board- Thanks to Dell-this was brought to my attention. Dell, I gave my husband your answer to the problem of : broken timing gear, #1 piston TDC, fly wheel timing mark set @ zero, installed new timing gear with #1 TDC and mark on fly wheel @ zero. The crank shaft gear timing mark does not align itself with the cam timing gear mark. Cam shaft gear is apprx. at 2 o'clock. My husbands response was: so it means that the cams don't line up and then he just ignored me and said "sorry, but I'm trying to fix this. I e-mailed you and asked if your answer to me was for a side or front mount. I don't know why I'm trying to help the grouch, guess thats what love is!
Dell (WA)
01-26-2002 18:56:33
 Re: 1950'ish 8N side mount timing gear in reply to Barbara, 01-26-2002 15:55:32
Barbara..... .with this timing gear "miss-mark" problem that has just recently (last couple of years) showed up. You have to ignore the camshaft gear witness mark in respect to the crankshaft gear.
Set your camshaft so that BOTH #1 valves are seated (cross-check: both #4 valves are wide open) Turn crankshaft so #1 piston is TDC and then slide the camshaft gear into place with out moving eather units. You'll know when its right, 'cuz it'll be obvious. Then for the next poor guy that rebuilds that engine, drill a "correct" timing mark on the camshaft gear that'll line up with the crankshaft witness mark.
I know it flys against all engine rebuild practice. As I said the timing mark descrepancy is rather obvious if you're looking for it. Since most N-Engine rebuilds don't include replacing the camshaft gear, lot of rebuilders arn't having or noticing this problem, just the ones that replace the camshaft gear.
Good Luck, we care..... .Dell
Dell....any idea who makes these gears???rasputen
01-26-2002 23:19:29
 Re: Re: 1950'ish 8N side mount timing gear in reply to Dell (WA), 01-26-2002 18:56:33
Just wondering if we should be wary of certian mfg's of N timing gears.
Also would the supplier not know and demand the correctly marked gears from mfg.??
bd
RSP
01-27-2002 05:28:46
 Re: Re: Re: 1950'ish 8N side mount timing gear in reply to Dell....any idea who makes these gears???rasputen, 01-26-2002 23:19:29
I had one not marked at all they seem to be taiwan with a name like that no wonder they dont know how to mark them but basically you should check your valve timing without reference to the marks it types out easier than it is but..... .RSP
Dell (WA)
01-26-2002 23:35:06
Don't know who is manufacturing these miss-marked camshaft timing gears, sorry. Maybe Barbara can supply that information if'n the box ain't been thrown out. How about it Barbara???
This is the 4th one within the past month that I personally have responded to..... ..Dell
Dave Smith,
01-27-2002 04:30:49
 Re: Re: Re: Re: 1950'ish 8N side mount timing gear in reply to Dell (WA), 01-26-2002 23:35:06
Are they the fiber or the metal gears?
Dave <*)))><
Barbara
01-27-2002 09:49:43
 Re: Re: Re: Re: Re: 1950'ish 8N side mount timing gear in reply to Dave Smith,, 01-27-2002 04:30:49
Hi, the timing gear was bought from New Holland. It is aluminum, the one that broke is fiber. The numbers on the box are: part no. 7RA6256A pcs. 0001 Made In USA finis. 00000 000 D01 209440 10/94
This is all on the box, hope it all makes sense to you.
thank you . . . Dell
01-27-2002 11:54:58
 Re: Re: Re: Re: Re: Re: 1950'ish 8N side mount timing gear in reply to Barbara, 01-27-2002 09:49:43
Barbara..... .thanks for info on camshaft gear.
Hows it goin?..... Dell
Barbara
01-27-2002 13:30:06
 Re: Re: Re: Re: Re: Re: Re: 1950'ish 8N side mount timing gear in reply to thank you . . . Dell, 01-27-2002 11:54:58
Husband at stand still, he isn't understandinhg the written, any chance of landline talk? you can e-mail or we could talk hotmail? Oh, you are welcome for the info, does it make sense and help?
check yer e-mail . . . Dell (WA)
01-27-2002 15:25:36
 Re: Re: Re: Re: Re: Re: Re: Re: 1950'ish 8N side mount timing gear in reply to Barbara, 01-27-2002 13:30:06
Barbara..... . I have NO e-mail voice..... Dell
RSP
01-27-2002 05:30:31
the ones I have seen are taiwan fiber gears JUNK
