High engine speed lean out
RSP
01-27-2002 04:55:11
I had this 8-n every thing has been overhauled and done correctly but every time i went to full accell the engine would go lean and only at full throttle i have tried everything finally i pulled the long ( high speed) screw all the way out and this thing ran perfectly so I disassembled the carb for the who knows how many time and took a drill and drilled out the brass jet? where the needle seats on to I think I went up two drill sizes from org then took a hammer and tapped the needle to seat it on the new hole put the carb back together and finallt i have no more high speed lean problems JUST a note there were no vacume leaks anywhere I know that this sounds like one but there was none just passing on some info. on what seemed to be a difficult problem RSP
Greg
01-27-2002 05:39:23
 Re: High engine speed lean out in reply to RSP, 01-27-2002 04:55:11
RSP,
How do you know there weren't any vacumn leaks?
How many inches of vacumn were you pulling at idle?
Hate to say this but I think you just threw a lot more fuel at a vacumn leaking condition. JMHO
tj
01-27-2002 05:45:05
 Re: Re: High engine speed lean out in reply to Greg, 01-27-2002 05:39:23
Could be that someone might have put wrong size jet in, there are several sizes this one may have been too small for the needle that was used.
RSP
01-27-2002 06:03:46
 Re: Re: Re: High engine speed lean out in reply to tj, 01-27-2002 05:45:05
Im a ford 20 year at same place Ford Masters mechanic trust me no vacume leaks
Dell (WA)
01-27-2002 08:09:37
 Re: Re: Re: Re: High engine speed lean out in reply to RSP, 01-27-2002 06:03:46
RSP..... ..good catch, something only years of experience could identify and have the knowledge of "how-to fix". Thank you for sharing..... ..Dell
