Changed Hydraulic fluid added 5 gals. but still shows low on dip stick???
Rick
01-27-2002 16:53:33
I changed the Hyd./Trans. fluid the other day in my 8N. I refilled it with 5 gals. of hyd/trans. fluid from the ford dealer. I drove it down the road and parked it in the garage. I went to the garage the next morning to check it out and when I pulled the dip stick it showed low. There was hardly any fluid on the dipstick. I wiped the dip stick off and checked it 3 more times same result. There were no leaks on the floor. So what is going on? I don't want to add more. I know it takes 5 gals.? Nothing seems wrong about the dipstick? What do you guys think?
Thanks.
Bill W.
01-27-2002 17:37:53
 Re: Changed Hydraulic fluid added 5 gals. but still shows low on dip stick??? in reply to Rick, 01-27-2002 16:53:33
If you put 5 gal. (U.S) that is a gracious plenty. You actually don't want to put but 4 3/4 gallons to keep excess fluid out of axel bearing area and thus prevent leaks around axel bearings. Otherwise, you need a longer dipstick.
Rick
01-28-2002 15:07:04
 Re: Re: Changed Hydraulic fluid added 5 gals. but still shows low on dip stick??? in reply to Bill W., 01-27-2002 17:37:53
Bill, It is the original dip stick for my 8N.?
Think it might have shrunk with age?
I have already made a complete fool of myself on a post entitled length of dipstick will not do it again.
01-27-2002 17:13:29
x
was it this post?
01-28-2002 16:28:27
 Re: Re: Changed Hydraulic fluid added 5 gals. but still shows low on dip stick??? in reply to I have already made a complete fool of myself on a post entitled length of dipstick will not do it again., 01-27-2002 17:13:29
did your wife assist you in that measurement
