Order Ford 9N Parts Online
9N ser#9NBN43235 strange???
9N141
01-31-2002 16:47:10
I just bought tractor with ser#9NBN43235. This is a strange # HELP It has alum dash I beam radius rods ete.
Scott
02-01-2002 10:15:34
 Re: 9N ser#9NBN43235 strange??? in reply to 9N141 , 01-31-2002 16:47:10
The industrial version was called 9NBN but the one i've seen just has a 9N prefix to the serial#. Moto tug tractors had a BNO prefix. These engines were interchangable so could have been switched.
EDDIE8N
01-31-2002 17:11:11
Are you sure it isn't 9NAN...
The NAN would designate thah it was configured to run on kerosene.
9N141
01-31-2002 18:59:56
 Re: Re: 9N ser#9NBN43235 strange??? in reply to EDDIE8N, 01-31-2002 17:11:11
It could be 9NAN # is hard to read. The alum dash,alum trans cover,rear fender bolt holes through axle are closed,etc., all seem to point to 1939 or 1940 9N. Any ideas????
EDDIE8N
01-31-2002 19:28:33
 Re: Re: Re: 9N ser#9NBN43235 strange??? in reply to 9N141, 01-31-2002 18:59:56
According to the last 5 digits of ser. number it would be a 1940. See the menu on the left side of your screen, click on Serial Numbers under the heading RESEARCH & INFO
See post below as far as other distinguishing characteristics.
If you have an I&T FO-4 manual, it has a picture on page 117 showing the difference in the manifold that OLD GEORGE was refering to.
EDDIE8N
9N141
01-31-2002 18:00:25
More info please re manifold? comp? fuel tank etc. ????
Old George
01-31-2002 18:18:28
 Re: Re: Re: 9N ser#9NBN43235 strange??? in reply to 9N141, 01-31-2002 18:00:25
If it is an NAN it will have have a tank with dual caps for both gas and kero. They were started on gas and then switched over when warm. The manifold was of a slightly different design to heat the air/kero mixture. Other than that I understand them to be the same. Hope this helps.
Alan Esch
45 2N kit 183513
