Ole..... .."Cranks like a son of a gun", kinda sounds like no compression. Check your compression, even a new, unbroken engine should be up around 110-120 psi, my guess yer gonna read down around 77-80 psi. Unfortunately, theres been a rash of recent rebuilds affected with incorrect camshaft gear index marking. Its rather obvious if'n yer looking fer it. If'n your compression is low like I suspect, yer gonnna haffta take both the cylinder head and the timing gear cover off and visually inspect the position of the #1 valves both closed and the #1 piston TDC. You'll have to manually crank the camshaft around so that BOTH #1 valves are closed (cross-check both #4 valve open) You can tell by feeling the action of the valves with your fingers. REMOVE the camshaft gear. Now manually crank yer crankshaft until #1 cylinder is TDC with the index next to where the camgear (thats not installed right now) should be. NOW INSTALL the miss-indexed camshaft gear without moving anything. NOTE: the indexes will not match up if'n yer doin it right like I tell you. Now then, once ya gotts everything TDC'd, valves seated, piston TDC, drill a new index mark on the camshaft gear soes the next poor mechanic has a fightin' chance. As I say, the camshaft/crankshaft miss-timing is rather OBVIOUS if'n yer lookin' fer it..... ...Dell
