Rear hub
Adam
02-02-2002 16:22:42
Help..I noticed an oil leak on my rt rear tire, so I jacked it up and there was a lot of play, side to side. So I cranked down on the nut. This didn't work, so I bought a new hub. put it all back together and no play. great it's fixed, nope. I drove around a few minutes and you could hear grinding inside. I took everything off and the hub is now rubbing on the thing that goes on before the brake shoes. Does this mean that the axle is warn..? The hub seems to be going in to far. Did I forget something or do I need a new axel..?
Scott
02-02-2002 18:37:10
 Re: Rear hub in reply to Adam, 02-02-2002 16:22:42
When replacing the parts it is very important to follow the shimming procedure or it will soon leak again, tell your dealer your serial# when getting parts so you get the correct seals, 1947-1949 used an outer seal in a metal retainer with a gasket behind and a cork ring behind the hub, 1949-1952 had an additional inner seal, late 1952 used an outer seal in the cup housing instead of the retainer. If you don't understand something just ask.
KCM
02-02-2002 16:33:12
Sounds like the axle is too worn and you will need to replace it. Sometimes a new hub is enough, sometimes it isn't. The splines wearing is common on 8N's as people would let the nuts get loose (they should be periodically tightened).
My dad had a tractor that always made this singing noise off and on when it was moving, years later we took the rear hub off and found out it had went in so far that it was rubbing the brake spring. Replacing the hub did the trick on it.
