Order Ford 9N Parts Online
41 9N hydraulic lift lever keeps popping up?
Paul in Forsyth
02-03-2002 06:38:19
I worked my 9N hard yesterday for the first time. Everything worked well at first. Then I noticed that after I lowered the lift, after a few minutes the lever would be in the center position and the lift would raise up a bit.
This seemed to get worse as the day went on.
When I was unhooking a tilt bucket from the back it was like a ghost was working the hydraulics. I'd lower the lift walk in back to unhook the bucket and the lift would come back up.
Rich Lohmann
02-04-2002 09:29:55
 Re: 41 9N hydraulic lift lever keeps popping up? in reply to Paul in Forsyth, GA, 02-03-2002 06:38:19
Paul, your ghost must make house-calls, as I have been plagued with this same problem for years! Anytime the engine is running and the PTO is engaged, my '41 9N will raise the lift arms if I don't keep my hand on the control lever. I had already tried tightening the tensioning screw and replacing the cork gasket, but still the problem remains. I am getting tired of bush hogging my pastures with one hand on the steering wheel and the other holding down the hydraulics. As far as installing a Zane Thang, I have never seen one and it's quite obvious from the feedback on this board that it's an excellent product. However, I would hate to install it and turn my back on this problem. I would at least like to solve it before moving on the next task. Has anyone else ever encountered this problem and what is the cause? Any help would be greatly appreciated!
Bill N.Y.
02-05-2002 15:13:07
 Re: Re: 41 9N hydraulic lift lever keeps popping up? in reply to Rich Lohmann, 02-04-2002 09:29:55
I had the same problem for some time. I adjusted
this, I adjusted that, nothing. I bought a
Zane Thang. Installed it today. Problem solved.
Zane for President!!!
Chip Williams
02-04-2002 16:30:13
I bet you just need a thicker cork disk. The one I made is 1/4" thick, and if I had wanted to, I could have tightened the spring & nut tight enough that I wouldn't be able to move the lever at all. My $.02..... .
Rich Lohmann
02-04-2002 09:28:56
Rich Lohmann
02-04-2002 09:23:14
ZANE
02-03-2002 09:12:05
You gotta get a ZANE THANG position control for that tractor. The 9N didn't have the option of position or height control. Only draft control.
When you install the ZANE THANG you can then disable the quadrant friction clutch because you won't need it anymore.
See the link below for more information
John, pa
02-03-2002 07:13:21
To the rear of the lift lever there is a tension nut assembly. I would Try turning the tensioning nut a little to put a little more pressure on the lever.
Chip Williams
02-03-2002 15:06:16
 Re: Re: 41 9N hydraulic lift lever keeps popping up? in reply to John, pa, 02-03-2002 07:13:21
I just fixed this problem yesterday on my 43 2N, with thanks to the folks on this board. There is a 2" or so diameter disk on the control lever. Behind this disk is a cork friction disk. I replaced the cork and now mine works fine. I made my own using 2 thicknesses of 1/8" gasket material cut to the diameter of the disk. Works great.
