Live Hyd. Update?
Phil (GA)
02-03-2002 06:39:37
Has anyone heard if the "Zanedraulics" are working yet?
ZANE
02-03-2002 09:07:39
 Re: Live Hyd. Update? in reply to Phil (GA), 02-03-2002 06:39:37
I have ordered a couple of pumps and check valves and am waiting for them to be delivered.
Hoses I can get locally.
Then I want to get this ugly 52 8N that I just bought back together and painted so I can mount it on her. Ran into a pretty bad problem when I pulled out the last two sleeves. Both cylinders were broken through where someone in the past has apparently tried to peel out a set of cast iron sleeves. NOT! They must be pulled one way or the other. No peeling! Too late! already done on this one. The two that were broken were glued in probably with epoxy. I will do the same when I get the new sleeves etc.
There goes my idea to put .080 pistons back in.
It may be a couple of weeks before I get everything together. I will post results when I do get it done.
I'm trying!!!!
Mike
02-03-2002 17:50:50
 Re: Re: Live Hyd. Update? in reply to ZANE, 02-03-2002 09:07:39
Hey Zane,
don't ya' just love it when some one does something like that. If it was easy everyone would be doin' it. Good luck, you're gona' need it.
Mike
DHofTally
02-03-2002 15:10:51
what is the difference between Peeling and Pulling the sleeves
