Oil Presure Question
Sal
02-04-2002 11:25:38
My 51 8N was overhauled about 1 yr ago with new valves, rings, etc...
The Oil Pressure on start up at 1/2 -2/3 throtle is at 42 and stays there unless working very hard like hogging for 2 hours or more then goes to 37-38.
If I go up to full throtle the presure goes up to 46-47.
If I got down to about 1/5 throtle the presure goes down to 37-38.
Seems like a lot of folks here have big drops in oil pressure when the N is warmed up. Is that what it should do?...or do I have a problem with a valve?...or are things just fine?
Thanks.
Sal
John, PA
02-04-2002 11:57:55
 Re: Oil Presure Question in reply to Sal, 02-04-2002 11:25:38
What weight of oil are you using?
I don't think you have any problem.
Had a 9n once that had the oil pressure line purposely flattened so that oil pressure gage didn't read so high. I guess that it was a field repair. Honest.
Sal
02-04-2002 12:06:11
 Re: Re: Oil Presure Question in reply to John, PA, 02-04-2002 11:57:55
I am using 10-30 oil and I have checked out the gauge(s).
Sal
john,PA
02-04-2002 12:13:12
 Re: Re: Re: Oil Presure Question in reply to Sal, 02-04-2002 12:06:11
Well Sal, if there no seals leaking I don't think that I'd worry about the oil pressure range being on the high end. Probably have great bearings. Right now I am hearing a rod bearing starting to rattle on my 1980 E-150 302 engine. I guess when it starts sounding like a diesel I'll overhaul. It has 300,000 miles on it.
