3pt. digger
Paul (WI)
02-06-2002 17:38:45
I am going to place an ad in the local paper looking for a 6' wide 3pt. digger. I don't know if this is the proper name for it. I have also heard it called a tiller. Dad always called it a digger. It looks like a cultivator except that it has straight shanks which are held in the downward position by two large horizontal springs above each shank. These springs allow the shank to move rearward if a large rock is hit and then will bring it back in place again. This is a very handy implement for smaller plots and unfortunately the one on the home farm is no longer around. Thanks for any help.
Larry, Mo.
02-07-2002 08:07:53
 Re: 3pt. digger in reply to Paul (WI), 02-06-2002 17:38:45
I also have what was described to me by my father as a "field cultivator". It is in need of a paint job. It is sorta red, but my father tended to paint everything red. Does anyone know what the color was orginally? Thanks for the conversation.
Gaspump
02-07-2002 08:40:36
 Re: Re: 3pt. digger in reply to Larry, Mo., 02-07-2002 08:07:53
If it is a Ford (Dearborn) same red as the 8N, If Ferguson, Dark Gray.
Tom-Pa
02-07-2002 07:33:08
Paul, What you are looking for is the 'Field Cultivator' That is the proper terminology. That is what Ferguson called it and so did Dearborn. When I went to get new springs to replace the 3 missing ones I had, I found that by having the NH dealer go to the Dearborn parts catalog for them I was able to get the springs..
Good luck
Tom-Pa
Nogrimace
02-07-2002 05:06:16
Out west we either call them a culivator, the type with the duck foot or shovel on the end of the arm, or we call it the Spring Tooth. Lots of them around, you can pick up a 6 or 7 foot wide one here for 150.00. These kinda took the place of the drag type Disks. Although the disks are still used by farmers to till the ground after they harvest their wheat. Good luck on getting one. I guess the verbadge is just what people call them and pass it on to their kids.
Gaspump
02-07-2002 06:32:01
 Re: Re: 3pt. digger in reply to Ed Gooding (VA), 02-07-2002 04:55:56
That is what I refered to. Mine is a Model# 10-95 and came new with straight shank teeth. Nice pics again Ed!
Paul (WI)
02-07-2002 20:15:29
 Re: Re: Re: 3pt. digger in reply to Gaspump, 02-07-2002 06:32:01
Thanks Ed, for the picture it is exactly what I was talking about. It is a real handy implement but you can work the heck out of the tractor when using it. Thanks guys for the help.
tim[in]
02-06-2002 19:35:34
this a small version of a chisel plow .i believe they were caller tillers by one company. they were still made new up to a few years back. not sure if they still are or not.been thinking about one myself. just not much clearance for corn stalks. might have to bushog or disc first .
Gaspump
02-06-2002 17:49:00
I have one that was purchased with our new 1950 8N. We always refered to it as a field cultivator. I have used this tool for anything from breaking ground to pulling small stumps and roots. Sorry it's not for sale. I am sure somewhere I have the original manual for it.
