OT: Back Hoe
Sal
02-07-2002 06:33:06
I am interested in purchasing a backhoe for the use around my 45 acres. The machine needs to be reliable but not fancy.
I have been told that some of the older models with a fair amount of life left in them can be purchased in the $3k-$5k range.
Is this $ amount realistic?
What features should I look for.
What manufacturer is a good one to go with.
Thanks.
Sal
allen
02-07-2002 20:25:46
 Re: OT: Back Hoe in reply to Sal, 02-07-2002 06:33:06
hello to sal,larry and everybody else i never thought the idea of a backhoe on a 8n would be so controversial.i bought the 750 woods for my 8n because a used 3 to 5000 dollar full sized machine would dollar you to death.you would end up working on it all the time instead of using it.i told the dealer what tractor i was going to use and he said no problem.as soon as i mounted it and saw how it behaved i knew i would have to "beef up" top link rocker and still have not had any problems.i think the 750 weighs 200 lbs. less than the 7500.there is several good units for small tractors bush hog 662h at 654 lbs. other makes include arps,great bend & bradco.around here (east tn) backhoe service is 50 to 60 a hour with a 2 to 4 hr min. and they act like ther'e doing you a favor. besides i can take my small outfit where the big boys can't go. i just wondered what the sherman backhoe for the 8n weighed ? it looked like a beast to me. happy digging !!!
Errin OH
02-07-2002 18:21:31
To answer your question - Probably not. You may get lucky and find one for that price range but I doubt it will have much life left in it. I went shopping around a year ago and anything under 5,000 wasn't even running. 8500 seemed to be a point where you could get a working hoe but usally the buckets were used up. 10-12,000 can get ya one with life left in it. I opted to build one and since the 3pt seems light for this work I built a frame that bolted on to the tractor (53 NAA) and mounted the hoe to that. Ended up with a ok hoe for light work. Won't be pulling any stumps but digin in clay it does pretty good. She runs around 900 lbs and with the wide frame mount (under finder mounts) there not as much stress on the axel housings. Total cost 1200 + labor.
raytasch
02-07-2002 09:50:40
Sal A couple years ago I picked up a '60s vintage 4000 diesel with a 703 loader and 723 'hoe for $3200. It is anything but pretty but it works good after about $500. in hydraulic repairs. It needs paint but I did not buy it to look at. Good rubber. See it in ----- --folder. Look around. I have seen similar units for sale in that price range. IMO, don't put a hoe on an N.
ray
ED-Illinois
02-07-2002 10:03:54
 Re: Re: OT: Back Hoe in reply to raytasch, 02-07-2002 09:50:40
Could you give some reasons for why you would not put a backhoe (such as the woods 6500) onto an N series tractor? I am curious.
raytasch
02-07-2002 16:13:15
 Re: Re: Re: OT: Back Hoe in reply to ED-Illinois, 02-07-2002 10:03:54
Hi Ed,
I say that based on what I've see happen to a light tractor such as an N when a loader or hoe is put to WORK on one. I have seen the trumpets to rearend bolts break out. I have heard of transmission cases breaking into pieces from loader or backhoe use. I've heard of top link attachment points breaking out of Ns. I know lower three point attachment points are week. IMO a backhoe needs a full mount subframe to take the shock off the tractor or at least distribute the shock forces throughout the tractor and not just onto the rear axle or three point assembly. I know how much force is put on my 4000 when I am working the 'hoe and I sure would not want that hoe on my 8N. My 4000 has an additional 500 lb weight attached to the front frame and even with the loader bucket full the front end gets a little light at times when digging with the 'hoe. The 723 hoe and it's subframe is sized to fit the 4000 that has a heavier rear axle assembly than an N series. If you attached a 'hoe that is sized to the N you can probably get some meaningful light work out of it. I have observed light tractors, mainly Kowbotys, with 'hoes attached and they just do not have the weight/heft to do much serious digging. I am also baseing my beliefs on watching a larger tractor with a 'hoe working and comparing how my 4000 stacks up against them. Again, this is my opinion based on observation. I am sure there are others who have 'hoes on N series and like the combination. I am not familiar with the size of the Woods 'hoe you mention. Just like many will agree the N series makes a poor loader tractor, I think they would make a poor 'hoe tractor. Just 'ain't' built for the job.
JMHOs
ray
Larry 8N75381
02-07-2002 06:58:41
Sal,
What model tractor(s) do you have? You might be better off to get a three point hitch mounted backhoe. I have a Woods 750 that I use with my Ford 3000. When I don't need the hoe I take it off and use the 3000 for other chores. You need to match the size of your tractor with the hoe size. There are several TPH hoe makes, so you have a selection that should give you a match.
Regards,
Larry
Sal
02-07-2002 08:19:13
 Re: Re: OT: Back Hoe in reply to Larry 8N75381, 02-07-2002 06:58:41
Larry, I have a 51 & 52 8n...don't think they are really made for the heavier work that I would be looking to do...I don't have a loader on them and I don't really want to put one on them either. That is why I am looking at a unit tha would have the front loader, the hoe...and power steering...and be able to do the jobs well.
When I heard 3-5k for something decent I thought I would look into it...and that's where I am.
Thanks.
-Sal
ED-Illinois
02-07-2002 07:25:33
Larry - I have a question...
I went to the woods site and saw their three point hitch mounted backhoes with their own reservoir and PTO attached pump - very nice.
However I saw that the weight was in excess of 1100 pounds. I thought that the N could lift about 800 pounds on the hitch - do you have to chain your backhoe in the up position?
ED-Illinois
02-07-2002 09:57:29
 Re: Re: Re: Re: OT: Back Hoe in reply to Larry 8N75381, 02-07-2002 09:25:14
Follow-up...
Yea, that 750 looks big, however the woods 6500 is, per woods website, for a cat 1 three point hitch, 540 rpm pto, 15-35 horsepower tractor. Now, when that large pile of money falls from the sky, I know what I will get.
Also, do you need any extra weight on the front of the tractor during transport with the backhoe? If memory serves, the 9/2/8N weighs about 2600#. Accordingly, the 1000# on the back, close to the rear axle, should improve drive traction, and lighten up the steering.
But how light? I drove a case 850 one weekend with a loader and backhoe on it, and if I went forward too quickly, I could make the front wheels come off the ground and stay up for while.
Larry 8N75381
02-07-2002 12:00:05
 Re: Re: Re: Re: Re: OT: Back Hoe in reply to ED-Illinois, 02-07-2002 09:57:29
Ed, there was a thread on the Woods on an 8N back a week or so. Below is a reply I made at that time that adds to my previous comments.
On my 3000 I have 100# on the bumper right now, but have used the hoe before I put it on. With the weight on the front, I have NO problem with the front being too light.
I bought my 750 new. $$ouch!! But like almost every other tool I have bought and used, it would have been cheep at half again as much as I paid ($5000+) for all the things I have/can do with it. I had to put in almost 400' of well line, and repair the line from the septic tank to the distribution box. 'Cause I had the hoe I got to do these tasks on my own schedule, not a contractors!
Have you looked at some of the other hoe manufactures? Think there are some a bit smaller than the Woods that could be a better fit to the 8N.
ED-Illinois
02-07-2002 12:14:34
 Re: Re: Re: Re: Re: Re: OT: Back Hoe in reply to Larry 8N75381, 02-07-2002 12:00:05
Nope, I haven't checked any others out. Woods has a great reputation, but that doesn't necesarily mean it is the best - do you know of other manufacturers?
Larry 8N75381
02-07-2002 18:42:02
 Re: Re: Re: Re: Re: Re: Re: OT: Back Hoe in reply to ED-Illinois, 02-07-2002 12:14:34
I found the Bush Hog site below with four sizes of backhoes. But I keep thinking that there is at least one other company like King Kutter (but it is not them) that is not a tractor manufacture but strictly an implement manufacturer.
There are also kit/plans for building your own. A Google search on backhoe found www.ubuilditplans.com which has plans for a self powered unit that I think could be adapted for a TPH and I am pretty sure Cadplans has a hoe.
To add to what raytasch said, the 750 can easily pull my 3000 around. It is a strange feeling when you try to pull up something that won't come, and the rear of the tractor "squats" down from the load. He is probably right about the need for a sub frame. A TPH hoe hangs ALL its' weight PLUS the digging load off the top link rocker! That is why the Woods replacement for the rocker is REALLY heavy duty! In the earlier thread, allen, who has a 750 on an 8N, turns out to have made up a reenforcing "bracket" (for lack of a better description) to take the load off the rocker. Also, as I remember the real differences between the 650 and 750 (and their newer versions) is JUST the reach/depth/height maximums since the boom/dipper stick are shorter - thus the hoe is lighter. But the digging forces are essentially the same since they both use the same size cylinders and hydraulic pressure.
I stand corrected....(ED-Illinois)
02-07-2002 07:42:34
 Re: Re: Re: OT: Back Hoe in reply to ED-Illinois, 02-07-2002 07:25:33
third party image
I went back to the woods website and saw the 6500 (78" depth) weighs 950 lbs.
