I'm starting rebuild on my '43 2N. I've got the front end off and next weekend I expect I'll split the tractor and get the engine on the stand.I've had the head off before, so I know that I have domed pistons. I've been told that these are "super power" oversized pistons with .0825" sleeves. Is this correct? Rebuild kits come with either 3-ring or 4-ring pistons and either .040" or .090" sleeves, although you can buy the "super power" piston/sleeve sets separately. In the archives I've read a lot about 3-ring vs. 4-ring pistons, and it appears to me that, although some people swear by the 4-ring and most say they are OK, given a choice most of the members of this august body prefer the 3-ring piston. Soooo..... What about these oversized pistons? If I pull the pistons out and find the existing sleeves are not worn or tapered, should I leave the sleeves and re-use the pistons I already have? Of course I would be replacing the rings and bearings and such. IF this turns out to be the case, I can save a good deal of money by buying the rebuild parts I need seperately instead of buying a kit. On the other hand, if I discover that either the pistons or sleeves need to be replaced, would you guys suggest I just get the standard 3-ring pistons with the .090" sleeves (I think that would be the size) or is there a real advantage ($40 worth) to the oversize pistons? Oh, one more thing. This past summer I cleaned, lapped and adjusted the valves. One valve is a little short, but the adjustable lifters I bought make up for it; I can set the clearance just fine. Is there any good reason for getting brand new valves, guides, springs, etc.? I can save a good deal of money here too if I don't have to buy new valves. I haven't posted in a while but I do enjoy reading all of your posts and replies, and I have been reading in the archives whenever I log on, so I want to thank all of you for the help I've aready received from this great forum.
