Order Ford 8N Parts Online
Another 8N Question
Arne Carlson
02-10-2002 16:01:22
Hello,
Thanks to all for the answers to my transmission oil questions. They are very helpful.
After looking the tractor over more closely, I can see it is in need of the pin that attach the radius arm to the front axle (both sides). (I am using Ford F-150 terms here, I hope they apply to the 8N) Can a grade 8 bolt be used here? Is the part available? If so, the real part description or part no. would be greatly appreciated.
Thanks again,
Arne Carlson
Eagle, ID USA
Arne Carlson
02-10-2002 17:20:38
 Re: Another 8N Question in reply to Arne Carlson, 02-10-2002 16:01:22
Thanks folks!
Wow, what a great board this is!
Arne
raytasch
02-10-2002 16:26:53
Arne, Your terminology is correct. A grade 8 bolt will work quite well. The correct part # is 357623S and they are available. If you have problems getting the old ones out there is lots of information in the archives.
ray
don b
02-11-2002 10:59:04
 Re: Re: Another 8N Question in reply to raytasch, 02-10-2002 16:26:53
A regular hex head bolt will not work on the 8n,unless you don't want to turn the steering wheel.The bolt is correct for the 9n.The 8ns have a recess in the radius arm for the correct pin to recess down and out of the way. don
