Resistors, what are they for?
Rob
02-10-2002 18:46:36
what is the purpose for a resistor? i havea 1950 8n and somone told me i had to have a resistor on the wire leading to the coil, from the switch. what is it for?
Dave Smith
02-10-2002 19:06:01
 Re: Resistors, what are they for? in reply to Rob, 02-10-2002 18:46:36
It is a ballast resistor. It cuts the voltage down to 2.5 to 3 volts at the coil. Without it you will burn out the coil.
Dave <*)))><
Rob
02-10-2002 19:10:57
 Re: Re: Resistors, what are they for? in reply to Dave Smith, 02-10-2002 19:06:01
i have one i put on, i am running a 12 volt system. i checked voltage on the inside and it read 12.5 v. i checked the voltage on the outside and it read the same? this is brand new out of the box. is that right?
Dave Smith, Yes
02-10-2002 19:20:17
 Re: Re: Re: Resistors, what are they for? in reply to Rob, 02-10-2002 19:10:57
Read the voltage at the top of the coil. With the points open you will have full battery voltage. With the points closed you should have about 7 and 1/2 volts. The difference is what the resistor is dropping.
Dave <*)))><
